Z1000st flasher unit
paulstrees
#1 PostAuthor: paulstrees » Sun Oct 12, 2008 4:04 pm
Are the flasher and hazard warning relays the same spec 12v/10W on the ST
ted1r
RELAYS
#2 PostAuthor: ted1r » Sun Oct 12, 2008 6:02 pm
HI MATE ARE YOUR RELAYS THE SAME AS A Z1R WITH 3 PINS?IF SO I`VE GOT ELECTRICAIN MATE WHO PUT ME ELECTRONIC ONE`S IN AND THEY ARE FANTASTIC THEY ONLY 6 QUID EACHIF YOU WANT I`LL POST YOU SOME OR I CAN BRING THEM TO STAFF ON SUN
TED
tlc
#3 PostAuthor: tlc » Sun Oct 12, 2008 6:36 pm
I got mine from the local auto electrician.
The flasher relay is rated at 12/21w X 2
The hazard relay is rated at 12/21w X 4 + (3w I think)
I`m only not sure about the little bit extra but it is something close to that.
They cost £3.50 each plus VAT
