re jetting z750 4cyl
stephen lavery
- Regular Poster
can anybody help me with jetting on a z750 4cyl running 125 main jets k\n filters with custom made 4 into 4 drag pipes. i dont know original size of jets so not sure were to start. may be 115 jets? running poorly at moment.
stevie the babarian
- big green bus
the standard size on a gpz750 is 125. i fitted a dyna jet kit to mine and the main jet was a 180!!!!!. you would also need to fit an air corrector jet with about a .3 hole in it. i will check mine tomorrow and find out exactly. you will also need to move the needle clip. i will be intouch unless someone on the site can give you a bit more info
stephen lavery
- Regular Poster
- Dark Skies
If you go to the Kawasaki part search facility you should be able to find a parts schematic that tells you the jet size:
http://www.kawasaki.com/DefaultFrame.as ... ehicle.asp?
KZ1000-M1 CSR
- big green bus
stephen lavery
- Regular Poster
