z1b swingarm needle roller conversion ??????
Pasc
#1 PostAuthor: Pasc » Tue Oct 28, 2008 6:20 pm
I seem to remember a while ago someone mentioned a needle roller bearing conversion for the z1b. Does anyone have any information on this or have I got it completely wrong ?
Are the original bushes etc available ?
I have a box section arm on at the moment but have a std arm waiting to go in but it has no bearings/ bushes spacers etc so I will need the lot.
dr.rod
#2 PostAuthor: dr.rod » Tue Oct 28, 2008 6:31 pm
I used Z900A4 parts to convert my Z1A. There's a little bit of lathe work required as the centre spacers are slightly different and you'll need to turn the ends off the old bushes to space the swing arm correctly into the frame. I covered it in the rebuild series in CMM, it's in there somewhere if you dig through the back issues.
london calling
#3 PostAuthor: london calling » Tue Oct 28, 2008 6:35 pm
Me finks the Z900 runs on bushes and the Z1000 was on needle rollers :??
Jack
Pasc
#4 PostAuthor: Pasc » Tue Oct 28, 2008 7:35 pm
Cheers Rod / Jack.
When I get 5 mins I'll run it by Mr Marsden.
Davy Doherty
#5 PostAuthor: Davy Doherty » Tue Oct 28, 2008 7:58 pm
Pasc, Jeff at Z1 has them, better get them before the dollar drops anymore
Users browsing this forum: Google [Bot], Noblester and 61 guests
