Hi guys
I want to remove my front brake splitter from the bottom yoke of my Z1000a2 and run two full length braided lines....
How can I get a front brake light cos the switch is on the splitter ??
Someone must have had the same problem.
No front brake splitter....brake light ??
Or you can put a ED20 brake switch holder in one of the lines and put the switch into that.
http://www.earls.co.uk/earls/motorbike_ ... tings.html
Front brake switches are only compulsory from about 1981 - onwards i fink
Monk, I have an in line brake pressure switch on me Black Zed... but the thing isn't very sensitive, and only works when you brake fairly hard
Anyway, i always disconnect the front, coz sometimes its handy to brake without attracting too much attention to the fact
I disconected the front switch on me z1000(2003). works well when people are following, they cant belive i hardly brake.
I use the rear now and again to make em think it works ok. (suppose not the done thing really
think the law says the brake light only needs to be operated by one means,(on bikes up to mid 1980ish) it doesnt say whether that is the front lever or the foot brake so it should be ok with just the rear. me z1a at the moment has only the front switch connected at the moment till me new rear switch arrives.
