Z1 (73-76) CLUTCH HUB WANTED
MaineKZ
#1 PostAuthor: MaineKZ » Sun Nov 09, 2008 8:45 am
Oops!! - had a bit of a mishap trying to undo that bastard great nut which secures the Clutch Hub (ie the inner 'drum' that the clutch plates fit over) :roll:
I kinda though the stripdown was all going a bit too smoothly...
Anyone got a good serviceable one kicking around? Mine's a 73, but I believe the part is unchanged for all 900 models 73-76.
Pls PM, email chrissmith@independenttalent.com or call 07771 613 688
neilbarrett
clutch hub
#2 PostAuthor: neilbarrett » Mon Nov 10, 2008 7:38 pm
you after the inner hub or the nut ?
#3 PostAuthor: Pigford » Mon Nov 10, 2008 7:42 pm
I'd image the clumsy clot has mashed the zinc alloy HUB...... :roll:
MaineKZ
#4 PostAuthor: MaineKZ » Mon Nov 10, 2008 8:58 pm
Pigford wrote:I'd image the clumsy clot has mashed the zinc alloy HUB...... :roll:
Got it in one Mr P!! :oops: :roll:
Neil - It's the inner hub I need
bunnysZ
Granny Magnet
#5 PostAuthor: bunnysZ » Tue Nov 11, 2008 10:24 am
MKZ
I have one its off an ltd model, not sure what year though , pm sent ,
