swing arm sizes
mikey
swing arm sizes
#1 PostAuthor: mikey » Tue Nov 25, 2008 5:23 pm
Seems my A2 swing arm was bent after all in my rear end shunt what i had couple weeks ago in the end were the wheel spindle sits, pigford has very kindly offered me an arm off a Z1000J but measurements seem a bit diffrent is this right or have i just measured it wrong will a J swingarm fit an A2?
Steve Cooke
#2 PostAuthor: Steve Cooke » Tue Nov 25, 2008 5:31 pm
Mikey i've got an A1/A2 swingarm you can have if you want it.
london calling
#3 PostAuthor: london calling » Tue Nov 25, 2008 5:32 pm
Uncle Fester,the J arm is 235 wide at the pivot point which I'm sure is wider than the Z1000 A2 arm.
Jack
mikey
#4 PostAuthor: mikey » Tue Nov 25, 2008 5:38 pm
Uncle gester? cheeky git cheers for the info jack, steve you have pm thanks mate
Steve Cooke
#5 PostAuthor: Steve Cooke » Tue Nov 25, 2008 5:41 pm
A2 pivot is 229mm wide.
