valve guides
Hobbo
International Rep
valve guides
#1 PostAuthor: Hobbo » Wed Jan 03, 2007 8:41 pm
Hi all
Just started to fit valves back into head and there dosnt seem to be a lip at the top of valve guide for oil seal to locate . Is this normal and have i got wrong seals or has last owner fitted wrong guides with the head work he did
phil ( :jake z1b )
International Rep
#2 PostAuthor: Rich » Wed Jan 03, 2007 9:18 pm
Std guides have a groove in to locate the seal.
Garn 1
#3 PostAuthor: Garn 1 » Wed Jan 03, 2007 9:30 pm
Hobbo, any valve guide that I have seen has a groove or recess for the valve seal to be retained. The only thing I can think of is that they may have been installed upside down.
Check all, both inlet and outlet and see if they are the same. Then check from the combustion chamber side or the lip or groove. In the event that I am correct, heat the head in an oven and carefully press them out and reverve them...... It is most unusual, but it could have happened!
To check on the profile of the guides refer to "Z1 Enterprises web site" illustration. Look under valve guides Z900A4 (Not Z1), Engine, page 6. The only difference in the profile is some have a circlip to prevent them going too far into the head, others have a step. All have a groove, lip or recess to take the valve guide seal.
RegardZ
kiwiz
#4 PostAuthor: kiwiz » Thu Jan 04, 2007 8:11 pm
Agree either wrong guides or upside down
Jerry
President
President
#5 PostAuthor: Jerry » Mon Jan 08, 2007 2:52 pm
wot a bugger!
Garn 1
#6 PostAuthor: Garn 1 » Tue Jan 16, 2007 8:25 am
Hobb0,
So, what's the story... How about some feedback? It would be nice to close this episode! You have probably put it away for winter?
RegardZ
Hobbo
International Rep
#7 PostAuthor: Hobbo » Thu Jan 18, 2007 6:17 pm
SORRY CHAPS
TAKEN THE HEAD TO LOCAL CHAP THAT DOES THESE FOR A LIVING HE LOVINGLY FITTED NEW SEALS IN AND LAPPED ALL VALVES IN FOR ME ?20 BARGAIN SORTED NOW BACK ON
PHIL
International Rep
kiwiz
#8 PostAuthor: kiwiz » Thu Jan 18, 2007 6:25 pm
Hobbo,
what was the story with the guides?
Garn 1
#9 PostAuthor: Garn 1 » Fri Jan 19, 2007 12:16 am
Yeah Hobbo, what about the guides with "no-lip" situation. I'm thinking maybe there was a lip there all the time, and it went un-noticed. Pretty hard to see sometimes!
RegardZ.
