Help Cam Chain Timing
Thought I was doing some routine maintenance until I adjusted the cam chain! I turned over the engine and it went tight. After a while it turned over but wouldn't start. I realize now the chain has jumped. I have removed the cam cover, loosened the tensioner and removed cam chain guide. Are there any ways to put it back to the original timing without breaking the chain?
Any help would be appreciated.
Bill
Bill
Lost in the desert somewhere
You need to slacken the adjuster & remove the top idler sprocket first
(Assuming its an older Zed - chain not hy-vo)
Take your time & don't rush it......
I hate to say this..... But there's a good chance you've bent some valves
Check all cylinders compression of it won't start..... just remove spark plugs & turn engine over with thumb over plug holes....
GOOD LUCK.....
Been there, done it, got the Tee Shirt... & new valves
Steve Cooke
- ZedHead
Steve Cooke
- ZedHead
- RALPHARAMA
if you haven't got a workshop manual let us know and we'll scan a page and post it on here. What model is it? Set the timing as it should be then borrow a compression tester and confirm that all is well. Prolly will be.
It is however worrying that the cam chain would jump if you set the cam chain tension in the prescribed manner. You couldn't have turned the engine in the wrong direction could you? If not I would be inclined to remove the tensioner, photograph it and post it on here. I have seen more than one that has been badly butchered.
You'll get all the help you need on here
Ralph Ferrand
Thanks VDUK,
I think this thread now has moved to the other cam chain help by Wingman. I do have a manual thanks but the info I have received on that thread has really helped. For instance the cam chain timing diagram and explanation by Chrisu is superb and much better than the workshop manual.
Bill
Bill
The motorcycle engineer has bottled out, so I am commited ro do this job on my own! I am going to start removing the head tommorow and post pictures as I go so I´ll start a new thread.
Apart from a 4lb hammer, chisle and a reel of sticky back plastic what specialised tools if any might I need?
Bill
Bill
- DogsbolloxofZ1B
As welll as removing the cylinder head nuts make sure you remove the M6 bolts adjacent to plugs 1 & 4 before you attempt to remove the head. To free off a head I use a large plastic mallet and a length of brass (covered with a rag) and tap the fat section of casting by these two M6 bolts above.
Never had any problems.
Mike
Mike
Users browsing this forum: Big Fluff and 90 guests
