Swinging arm taper bearings?
kwakerman
#1 PostAuthor: kwakerman » Sun Dec 21, 2008 8:23 pm
I,ve just bought a braced swining arm off ebay, seller said it was complete with bearings :) , had a look at it today & only one taper bearing included :x , it also seems that in order to fit taper bearing a sleeve is required for it to fit onto spindle, this is also missing :roll: .
Don,t know how to get link up but here is the item no. 270317689839.
Question is where can i buy a taper bearing to fit?
any help apreciated.
Jez
Not mad just kwakers
Z900A4 x2, Z1000A1 x2, z1000A2, z1r, z1a project & a load of bits
compo z1r
bearings
#2 PostAuthor: compo z1r » Sun Dec 21, 2008 9:06 pm
hi' a company called leeds bearings ltd you'll get any bearing poss there i wanted some for woodworking tools from the 1960's and they had them on the shelfs.
london calling
#3 PostAuthor: london calling » Sun Dec 21, 2008 9:12 pm
Looks like an early JMC arm to me,might be worth contacting 'em to see if they can help you out.
Jack
kwakerman
#4 PostAuthor: kwakerman » Sun Dec 21, 2008 9:16 pm
Thanks Compo, don't spose you've got thier number to hand :)
Jez
kwakerman
#5 PostAuthor: kwakerman » Sun Dec 21, 2008 9:22 pm
Cheers Jack, thought the same, it's been chromed but is wearing off
& has a bit of chain damage to the underside, thought i might get it blasted
repair the damage & get it painted to match the rest of the frame, when i manage to sort that one out.
Jez
compo z1r
bearings
#6 PostAuthor: compo z1r » Sun Dec 21, 2008 9:25 pm
yes' it 0113 2341919. ok
kwakerman
#7 PostAuthor: kwakerman » Sun Dec 21, 2008 9:39 pm
Nice one i'll give them a call
Jez
