dyna coil testing
hillbilly
dyna coil testing
#1 PostAuthor: hillbilly » Thu Jan 01, 2009 6:50 pm
dyna ignition ,how do you check if the pickup coils are ok.any suggestions. :oops: had some on mi bike an it wunt run right,(brand new)from debbens.could it have burnt mi coils out. :evil:
#2 PostAuthor: Rich » Fri Jan 02, 2009 8:53 am
Primary resistance should be 3 ohm between the low voltage terminals. Don't know what secondary resistance should be but there should be one. You could rig a spark tester as shown in Kawa manual. If the brass inserts in the end turn they break the LT conection.
hillbilly
#3 PostAuthor: hillbilly » Fri Jan 02, 2009 10:43 am
cheers for that mate,i got a start now to go on. :)
