O ring size Brake caliper Z9A4
bigmac103
#1 PostAuthor: bigmac103 » Fri Jan 09, 2009 11:01 pm
Does anyone the know the size of the O ring for the dust seal on the brake caliper for the Z900 A4?
Lost in the desert somewhere
Davy Doherty
#2 PostAuthor: Davy Doherty » Sun Jan 11, 2009 1:59 pm
someone must know or have a book to let you know
tlc
#3 PostAuthor: tlc » Sun Jan 11, 2009 2:57 pm
Dunno what you mean Biggy but I would just check the Z Power web site and order a set from them. Not many pounds and quick delivery :D
bigmac103
#4 PostAuthor: bigmac103 » Sun Jan 11, 2009 6:43 pm
I did and damaged them, as you do! I've actually found an excellent tool shop down here which supplies O rings. I have searched all my books but nothing about the actual size. I'm guessing they're 10mm. I agree Z Power is great in getting stuff out to me, it's just the postal service over here is a bit hit and miss.
mick znone
#5 PostAuthor: mick znone » Sun Jan 11, 2009 7:15 pm
got to strip my calipers down, think i have o rings missing as they clatter about on the bracket. i have a box of assorted o rings which i use for work and hoped to use them. any DIY shop or builders yard stock them. providing nothing gets in the way i am stripping them in the morning. according to the zpower parts book you need 8 rings for the a4 and 4 for the z1a. but there are all sorts of bits of rubber in them, so a will probably end up buying a kit.
bigmac103
#6 PostAuthor: bigmac103 » Sun Jan 11, 2009 7:30 pm
The trouble I had was getting the bolts to go through the bracket without trashing the rubber. When you say 8 O rings are needed do you mean 4 per caliper?
mick znone
#7 PostAuthor: mick znone » Sun Jan 11, 2009 7:35 pm
thats it, 4 per caliper, i coudnt work out why 8 for the a4, there are only 4 in the diagram, two calipers on the a4, 2 each side of the holding bracket.
bigmac103
#8 PostAuthor: bigmac103 » Sun Jan 11, 2009 7:40 pm
Try using a little vaseline, it certainly helped me!
