fuel tap help needed
zioclive
#1 PostAuthor: zioclive » Wed Jan 14, 2009 9:16 am
Almost six month ago, I've decided to disassemble the fuel tap of my z1R.
It was become so hard to turn that it was almost impossible opening or closing the fuel only using the hands .
Once disassembled I've changed all the gasket (3 if I don't get wrong) included in a “fuel petcock rebuild kitâ€￾ .
At the beginning the fuel tap was smoot (easy to turn I mean) but now is extremely hard again, exactly as it was :-/ .
What can I do to definitely solve this problem ?
I was thinking to change the fuel tap using something like this.
Do you think that it can be a good solution ?
I need some hints please.
Many thanks
Fabio
Taffus
#2 PostAuthor: Taffus » Wed Jan 14, 2009 10:54 am
The bottom tap is a Pingel. Got one on my 1100 works very well.
Jappen
#3 PostAuthor: Jappen » Wed Jan 14, 2009 11:15 am
Mont Pingel on my Z1000H,GREAT :!: Go for it :up :D
80-Z1000H
79-Z1000MK2
Murph
#4 PostAuthor: Murph » Wed Jan 14, 2009 7:15 pm
Cant go wrong with a pingel i've got one on my 1170 no problems .!!
Z9A4, Z1000a1 ZX10B1 ZX10B3 ZZR1100 ZG1200 VOYAGER
compo z1r
z1r
#5 PostAuthor: compo z1r » Wed Jan 14, 2009 7:51 pm
hi' ive' a spare z1r fuel tap perfect order :?: :roll:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
zioclive
#6 PostAuthor: zioclive » Fri Jan 16, 2009 5:48 pm
Many thanks, I think that using a Mont Pingel I should avoid the problem of rusted fuel . :)
toycollector10
#7 PostAuthor: toycollector10 » Fri Jan 16, 2009 8:21 pm
I used the same rebuild kit as well as a sleeve for the tap. Useless! The sleeve swelled up and turned to chewing gum.
A Pingel is the only tap that will work as far as I know
Kev1R
#8 PostAuthor: Kev1R » Fri Jan 16, 2009 8:50 pm
The Fuel tap on my (small tank) z1r is similarly stiff in operation - and has been for years. It is the same as the one in your photo. However I also have the larger tank which has a different fuel tap fitted. On the larger tank the actual tap part (ie the bit you grab hold of and turn) is bigger, so you can get more leverage on it and it is much easier and less fiddley to use.
You mention Rust ! If the source of the rust is your fuel tank - and not your Petrol Retailer ! - I would recommend you get it attended to prior to fitting a new tap. Especially such a fine and expensive piece of kit as a Pingel tap. which although it will have a gauze filter on it - is not really addressing this seperate issue.
zioclive
#9 PostAuthor: zioclive » Sat Jan 17, 2009 6:11 pm
Many thanks guys for the detailed answers.
I think the rust in the tank it will be hardly resolved.
Anyway I'll have to try, otherwise I'll never completely solve the problem .
Yes I agree the rebuild kit has been useless, low price > bad result .
Dark Skies
#10 PostAuthor: Dark Skies » Sat Jan 17, 2009 10:57 pm
toycollector10 wrote:I used the same rebuild kit as well as a sleeve for the tap. Useless! The sleeve swelled up and turned to chewing gum.
Yeah, I had the same problem with my CSR. Pingel is definitely the way to go.
KZ1000-M1 CSR
Users browsing this forum: KWACKERZ1 and 91 guests
