Z900 A4 ENGINE PROBLEM
BARRIE`S Z1
#1 PostAuthor: BARRIE`S Z1 » Sat Jan 13, 2007 5:03 pm
HI EVERYONE IM NEW TO THE BOARD BUT HAVE BEEN A MEMBER OF THE CLUB FOR A WHILE... NOW THE PROBLEM.. I HAVE A MINT 900A4 IN THE RARER COLOUR BROWN AND THE ENGINE SEEMS TO RUN UNEVEN OR TAKES A WHILE BEFORE IT TICK`S OVER EVENLY ALL THE CAM GEAR IS NICE AND QUIERT AS IT SHOULD BE IVE DONE A COMPRESSION TEST ON ALL 4 CYLINDERS AND THEY ARE ABOUT 130 PSI OR WITHIN A FEW POUNDS OF EACH OTHER AND SOMTIMES THE LEFT HAND CYLINDER POST WHEN FIRST STARTED OR UNTIL I CLEAN THE PLUG ON FIRST START UP I CAN SMELL BURNING ENGINE OIL BUT WITH NO BLUE SMOKE TO SPEAK OF ALL CARBS ARE BALANCED AND TIMING IS SPOT ON
CHEERS IN ADVANCE
BARRIE
P.S. ANYONE IN THE MIDDLESBROUGH AREA WHO KNOWS ABOUT ZED`S
phil churchett
#2 PostAuthor: phil churchett » Sat Jan 13, 2007 5:30 pm
Hi Barrie,
it may help if you could let us know the following;
How many miles has it done?
Has it been like this since you first owned it?
Does this happen on every start-up?
Does it have a standard air-box and exhaust?
Does it run/start OK once you have cleaned the l/h plug?
Once you have posted a reply to the above, i am sure some of us can come up with a few things to try :D
BARRIE`S Z1
#3 PostAuthor: BARRIE`S Z1 » Sat Jan 13, 2007 5:38 pm
THE BIKE IS STANDARD AND HAS DONE 28,000... AND YES IT HAPENS ON EVERY START UP .STANDARD AIRBOX AND NEW EXHAUSTS.. WHEN I HAVE CLEANED THE PLUG IT DOES RUN OK ON THAT CYLINDER BUT STILL WONT TICKOVER PROPLY
CHEERS
BARRIE
#4 PostAuthor: Pigford » Sat Jan 13, 2007 6:37 pm
BARRIE`S Z1, try swapping the leads & plugs round if u can on 1 & 4! If still dodgy only on left (#1) this will eliminate electical system. Could be air leak on carb rubber, common on old perished rubber bits! :roll:
DogsbolloxofZ1B
#5 PostAuthor: DogsbolloxofZ1B » Sat Jan 13, 2007 7:10 pm
If its only on initial start-up, and you've checked the basic electrical bits then I check the emulsifier tube is clear on that carb and ensure the hole in the carb base that the emulsifier tube sits in is clear too. Had a very similar issue with my Z1B.
#6 PostAuthor: Pigford » Sat Jan 13, 2007 7:37 pm
If the problem disappears shortly after 'warm-up' it may be in the choke system? :?: As in it ain't working proper on left one! :evil:
BARRIE`S Z1
#7 PostAuthor: BARRIE`S Z1 » Sat Jan 13, 2007 10:23 pm
COULD A STIKY VALVE CAUSE THIS PROBLEM
phil churchett
#8 PostAuthor: phil churchett » Sun Jan 14, 2007 5:18 pm
I did have this problem several years ago, but only when i left the bike on the side stand. Now, when it's in the garage, i always put it on the centre stand.
Hey presto, no problem.
Some people have a theory that while it's on the side stand, oil runs to the l/h side of the engine, resulting in the problem you have.
Garn 1
#9 PostAuthor: Garn 1 » Sun Jan 14, 2007 7:17 pm
Barry, I had a similar problem, took me a year to find.
I noticed one day after pulling the carb bowls off that two were very clean (not used much). These two were, (you guessed it!) served by the same fuel line.
Further inspect showed that this fuel line was partially blocked at the cock, where the inner part of the line had doubled up on itself. It had limited power at the start, however would run OK on a trip. I used to replace spark plugs, thinking that was the problem. I could imagine it giving a similar problem with just a one line system.
RegardZ.
