Spacer Width
mysticzed
Spacer Width
#1 PostAuthor: mysticzed » Thu Jan 22, 2009 10:10 pm
I am replacing an old JMC swinging arm with a new one. I think the old one has a custom made spacer between the rear wheel hub (brake side) and the arm. I suspect the new one will work with a standard spacer.
Could someone please advise the width of a standard spacer.
Many thanks.
whenwillitstopraining
mysticzed
#2 PostAuthor: mysticzed » Thu Jan 22, 2009 10:21 pm
Sorry should have said its for a Z900...same for all models 1972-1976...part no 42032-037.
Steve Cooke
#3 PostAuthor: Steve Cooke » Fri Jan 23, 2009 3:37 pm
I've just measured mine on the bike and it is somewhere between 34.5mm and 35mm.
