Spark Plugs
bigmac103
Spark Plugs
#1 PostAuthor: bigmac103 » Fri Jan 23, 2009 5:10 pm
I've recently switched from NGK to Denso IW24 plugs. Once she is running I can definitely state that she is much smoother at low rpm, in other words the lumpiness has gone. The trouble is starting, doesn't start on first go now and mostly the no. 2 gets wet and I have to take it out and clean it. Has anyone else had this problem or could it be something else???
As always any input appreciated.
B
Lost in the desert somewhere
tlc
#2 PostAuthor: tlc » Fri Jan 23, 2009 5:14 pm
Have you hot the number right ?
I thought they were W24 ESU
bigmac103
#3 PostAuthor: bigmac103 » Fri Jan 23, 2009 5:17 pm
Have I put the wrong plugs in? :oops:
london calling
#4 PostAuthor: london calling » Fri Jan 23, 2009 5:37 pm
IW are the iridium type plugs.
Jack
bigmac103
#5 PostAuthor: bigmac103 » Fri Jan 23, 2009 5:46 pm
Yes they are iridium, and according to the cross reference chart they are compatible, but are they ok for the Z900 engine?
london calling
#6 PostAuthor: london calling » Fri Jan 23, 2009 6:33 pm
They should be fine bigmac.
You might want to double check your carbs and maybe ignition coils/leads.
Maybe swap your plugs about to isolate the problem cylinder.
Jack
#7 PostAuthor: Pigford » Fri Jan 23, 2009 6:49 pm
I run them Denso Iridium plug in me Black Zed... :wink:
I use the '27' grade (tad cooler running), and they are OK :twisted:
bigmac103
#8 PostAuthor: bigmac103 » Fri Jan 23, 2009 6:50 pm
That's reassuring about the plugs thanks LC. The no. 2 plug fouled up when I first got the bike a couple of times and since I rebuilt the top end (Monday) it's happened twice, so maybe I ought to look at the carbs. Not a scooby doo where to start with the carbs mind you, but I'll learn.
tlc
#9 PostAuthor: tlc » Fri Jan 23, 2009 6:55 pm
You`re a bit of a fiddler aren`t you ?
I did my carbs and had a misfire on No.2 afterwards.
Turned out that the main jet fell out in that carb :oops:
I`d have a look inside the float bowls and the slides, a complete strip really, but make sure you have the means to balance them after !
london calling
#10 PostAuthor: london calling » Fri Jan 23, 2009 6:57 pm
You might want to get some Dyna/hi-output coils if you need to replace/up-grade your ignition.
Also check that you're getting a good reliable 12v feed to your coils.
www.denso-europe.com
Jack
#11 PostAuthor: chrisu » Fri Jan 23, 2009 7:11 pm
bigmac103
#12 PostAuthor: bigmac103 » Fri Jan 23, 2009 7:19 pm
Guilty as charged TLC :vis and thanks for those links guyz extremely useful another direction for me to fiddle in :up
london calling
#13 PostAuthor: london calling » Fri Jan 23, 2009 7:34 pm
The bike shop I use has got an electronic carb balancer which also has other usefull functions and is really accurate.
I'll get the make/model so you can look for mechanics/workshops for something similair where you are.
Jack
bigmac103
#14 PostAuthor: bigmac103 » Fri Jan 23, 2009 7:49 pm
Thanks LC.
london calling
#15 PostAuthor: london calling » Fri Jan 23, 2009 7:52 pm
No worries Bigmac,just send me some Spanish sunshine :wink:
Jack
Users browsing this forum: KWACKERZ1 and 91 guests
