Headlight stabilising bracket and warning stickers
Sorf
#1 PostAuthor: Sorf » Sun Jan 14, 2007 1:57 am
G'day all,
Regarding the above bracket on a 900-A4. Is it the same as the one on the Z1's? The only one I've seen on an A4, had a slotted end on it (for adjustment?) but the one pictured for the Z1 looks a tad different.
Also would a warning sticker set for a Z2 be more or less the same as the A4's?
Any thoughts?
Begging your pardon sir, but you did say that you'd like .................a green one?
Garn 1
#2 PostAuthor: Garn 1 » Mon Jan 15, 2007 9:58 am
Sorf, regarding that headlight stabiliser bracket, I think it's the same for all Z1 series. However, the Z1000 1A has a different one, I think it's similar to the Z650 bracket. Can't be sure with the A4, maybe they didn't have one!
Regarding Warning Sticers ~ I understand the Z2 came out in both types of frames. Firstly with the ones identical to the Z1 series, then with a frame as the Z900-A4. They would have been a difference in the under-seat sticker (battery drain-tube configuration) on these later models.
RegardZ
rickman CRR
#3 PostAuthor: rickman CRR » Mon Jan 15, 2007 10:38 am
I had a completely standard A4 from 1978-1997 and it didnt have a headlight steady bracket.
Sorf
#4 PostAuthor: Sorf » Mon Jan 15, 2007 11:41 am
Thanks,
Garn, from what you're saying, if the later Z2's came out with a frame as per the 900-A4, then wouldn't the battery drain be the same? (or not).
Rickman, I'm sure you're right! I just realised what both Garn and TPR had said on another forum. Geez, the old memory is struggling. :oops:
So OK, no bracket for the A4.
