Brake failure relay
PAULJAC47
Brake failure relay
#1 PostAuthor: PAULJAC47 » Sun Jan 25, 2009 4:32 pm
Hi All.Does anyone know where the brake failure relay is located on a Z1b and how to indentify it is not detailed in my manual only on the circuit diagram?
Garn 1
#2 PostAuthor: Garn 1 » Sun Jan 25, 2009 9:24 pm
Pauljac47, the brake outage unit on the Z1B is mounted off the left-hand-side coil, under the tank. It has a small special bracket and the unit is mounted in a rubber sheaf. The rubber is usually perished and tape is often used to retain the unit to the bracket.
RegardZ.
PAULJAC47
#3 PostAuthor: PAULJAC47 » Mon Jan 26, 2009 5:58 pm
Thanks Garn1, found unit ,can see in z power parts book as switch outage indicator but no part number!! must be unobtainable any way to test apart from substitution?
tlc
#4 PostAuthor: tlc » Mon Jan 26, 2009 6:19 pm
As far as I am aware if the unit fails then the lamp in the console will flash when the brake light is applied even though the lamp is okay.
They are available and I have seen for $60 new but also periodically on fleabay starting at $30.
If you save a search for "switch outage indicator" then they will show.
