Z1000-A1 rear foot peg fitting
tpr
#1 PostAuthor: tpr » Sat Jan 31, 2009 1:07 pm
I got some new Kawasaki rear footpegs but the holes on the pegs don't line up with those on the bracket. Any tips on how to make them fit?
Z900-A4, Z1000-A1
Steve Cooke
#2 PostAuthor: Steve Cooke » Sat Jan 31, 2009 1:13 pm
You should be able to force it by compressing the rubber then it wont rattle when fitted as long as the metal is not bottoming out on the inside.
tlc
#3 PostAuthor: tlc » Sat Jan 31, 2009 3:07 pm
What he said.
The rubber acts in the same way as a compression spring.
mick znone
#4 PostAuthor: mick znone » Sat Jan 31, 2009 5:40 pm
you could try putting the pegs in hot water for 5mins, if they are tuff.
tpr
#5 PostAuthor: tpr » Sun Feb 01, 2009 5:26 am
Thanks for your help. I had tried compressing the rubber but hot water was the key for these ones.
Z900-A4, Z1000-A1
mick znone
#6 PostAuthor: mick znone » Sun Feb 01, 2009 8:34 am
thats cool man, i found this method out after struggling with condoms, leave them in hot water for 5mins, then they will stretch to my size. incidently, 5mins i find is just enough time for the foreplay :lan
