A4 frame with no numbers
kwakerman
#1 PostAuthor: kwakerman » Mon Feb 09, 2009 12:19 am
I've just picked up a z900A4 frame with no numbers :cry:
does anyone know if it's possible to get it re numbered :?:
or will i have to register it on a Q plate :cry:
has anyone got a knackered frame, with or without log book, that i could pinch the numbers off :shock:
any help would be greatfully apreciated :wink:
cheers Jez
Not mad just kwakers
Z900A4 x2, Z1000A1 x2, z1000A2, z1r, z1a project & a load of bits
compo z1r
frame
#2 PostAuthor: compo z1r » Mon Feb 09, 2009 1:43 am
hi' have you got a log book for the frame if so yes.
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
kwakerman
#3 PostAuthor: kwakerman » Mon Feb 09, 2009 6:32 pm
no unfortunately it doesn't have a log book either :cry:
compo z1r
frame
#4 PostAuthor: compo z1r » Mon Feb 09, 2009 10:42 pm
kwakerman wrote:no unfortunately it doesn't have a log book either :cry:
do you have a log book to the engine you'll use if so it will have a frame no to it then stamp them no's to the frame. stamping kits are ready available.
kwakerman
#5 PostAuthor: kwakerman » Tue Feb 10, 2009 11:07 pm
Unfortunately the engine was bought off ebay, so no details there :( , but.......i've been on to DVLA today & they told me that once built i should be able to get a replacement frame number from them & as long as i can prove what year it is (dating cert from Jerry) they will then give me an age related plate for it :D , all i've got to do now is start putting it all together, wont be for about 6 weeks or so, but i will post pictures when i start
Jez
