Starting problems when warm
DAVE SULLIVAN
#1 PostAuthor: DAVE SULLIVAN » Sat Feb 14, 2009 2:26 pm
Hi all, just getting to grips with all this. I have a 1973 900 Z1 it starts and runs well from cold but cuts out and refuses to restart once warm but will bump start. I have cleaned the carbs all jets were blocked, bike has 4 into 4 exhaust wondered are baffles usually a probem? This is the first one I've owned would any appreciate any advice. I can do most jobs been spannering all my life but would be glad of some time saving tips. Bear with me as computers not my forte. :?:
Jerry
President
President
#2 PostAuthor: Jerry » Sat Feb 14, 2009 2:37 pm
My first thought is it's running way too rich - what are the plugs like?
Diesel
#3 PostAuthor: Diesel » Sat Feb 14, 2009 2:58 pm
other thing it could be is coils......
DAVE SULLIVAN
plugs
#4 PostAuthor: DAVE SULLIVAN » Sun Feb 15, 2009 1:24 am
Jerry wrote:My first thought is it's running way too rich - what are the plugs like?
plugs wern't black can anyone give me any info on airscrew setting's or tell me where i can download a manual from thanks Dave
Magnum1
#5 PostAuthor: Magnum1 » Sun Feb 15, 2009 10:21 am
Try Wired George
http://www.wgcarbs.com/
He knows a lot - click on the Forum for questions or do a search. If you sign up and ask a question, make sure you create a thread, so he can track the dialogue.
You might be getting too much fuel in the float bowls. Forget about checking the float height it's a waste of time on old bikes. Use clear tube from the drain below the float bowl, loosen the screw and the level should reach and not exceed the gasket mating surface of the bowl. Careful with the screws, that are normally seized or fucked.
Cheers,
Rod
Never heard of a Harris Magnum
DAVE SULLIVAN
#6 PostAuthor: DAVE SULLIVAN » Tue Feb 17, 2009 12:00 pm
THANK'S FOR THE INFO I FOUND BAD EARTH CONNECTIONS ON WIRING AND CLEANED THEM UP BIKE RUN'S A LOT BETTER REGARD'S DAVE
big green bus
#7 PostAuthor: big green bus » Thu Feb 19, 2009 6:46 pm
it is worth checking the shims if they are on the tight side once it warms up the gap will close keeping the valves from sealing and becomes a t**t to start (only a thought but worth a try)
