will a newer Zyphyr head fit the old Z1000 ?
i have a 1976 Z1000 engine, will a 92 Zephyr 1100 head (dual plugs) fit ?
You could try asking Rob at Mistral Engineering
http://www.mistralperformance.com/
He's loves an old Zed and has a lot of knowledge. If he does not know, his ex partner John Carpenter should know.
Good luck,
Rod
Good luck,
Rod
Never heard of a Harris Magnum
Re: will a newer Zyphyr head fit the old Z1000 ?
FJD wrote:i have a 1976 Z1000 engine, will a 92 Zephyr 1100 head (dual plugs) fit ?
This is gonna be velly interesting..... Be sure to keep us updated with your findings
- mick znone
Magnum1 wrote:Can APES build engines these days, fuckin el! I must be well out of the information circuit!
Seems they can Magnum1, some have learned to type on forums,
I am sure the studs are a different dimension apart. As Diesel has pointed out the cam guide wheels are missing so the cam chain drive would need to be re-engineered, another problem would be the combustion chamber volume which would require modifying. You would also need to fabricate an exhaust to fit as the ports are a different spacing. inlet ports are also different although you could fit the Zephyr carbs if they clear the Z tank, so the answer is it could be possible with lots of work, but I would ask why, 8 plugging the Z head is far simpler and a lot less expensive. Regards Steve
Users browsing this forum: Stugill and 44 guests
