sproc carrier
daveltd
sproc carrier
#1 PostAuthor: daveltd » Sun Feb 22, 2009 8:52 pm
Can anyone tell me what the diff is if any between z9 and z1000 rear sprocket carriers,cheers Dave
dmltd
london calling
#2 PostAuthor: london calling » Sun Feb 22, 2009 8:58 pm
Oh yes they're different :roll: :roll:
Jack
Garn 1
#3 PostAuthor: Garn 1 » Sun Feb 22, 2009 10:11 pm
Dave, they are certainly different. However, your forum name (DaveLTD)suggest that you may be comparing the Z900 Ltd to a Z1000 Ltd. these may be the same.
The normal z900 sprocket carrier is the same as Z1,Z1A & Z1B, whereas, the Z1000 carries a rear disk and is different. Some of the differences are.
    Shorter length of sprocket bolts
    Different size boss for sprocket *
    Different PCd for bolts *.
    Different shock drive rubbers.
This info * is from memory and could be incorrect, however it is certain that the carriers are not interchangable.
RegardZ
daveltd
sproc carrier
#4 PostAuthor: daveltd » Sun Feb 22, 2009 10:28 pm
Thanks guys for info,prob solved,cheers Dave
dmltd
