Stripped clutch on my Z1B today as I suspected that friction plates were worn (bite point is at very end of lever travel, have adjusted it without any improvement). Friction plates all measure 3.75- 3.8 mm thick, manual says replace if 3.5 or less so on the face of it they are OK. Anyone know what a new one measures? Springs are all 34.5 mm long, manual says replace if 32.3mm or less - again they appear OK- Are stronger springs worth while on standard motor?
Found one of the friction plates was broken! Anyone got a spare serviceable friction plate, I don't want to fork out for a full set if they are OK for wear. Will pay for plate + postage.
JR
Clutch plates
Clutch plates
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
- Ginger Bear
- Ginger Bear
Users browsing this forum: Bing [Bot] and 72 guests
