Piston ring compressor
Kari
#1 PostAuthor: Kari » Mon Mar 02, 2009 5:40 am
How you do it without Piston ring compressor Tool no. 57001-112 when you put your cylinder back to the base? Have you all gays a own Piston ring compressor by Kawasaki?
Garn 1
#2 PostAuthor: Garn 1 » Mon Mar 02, 2009 8:16 am
Kari, with respect... your question/ comment is a little hard to understand.
1. Are you asking for a loan of a piston ring compressor?
2. Are you asking, how do we put rings in to a set of barrels without a ring compressor?
3. Are you asking if we all have ring compressors?
4. Are you asking how we use the ring compressor?
I find them only good on 900 pistons, .005 mm over or .010 mm over.
Hard to use on 1000 pistons.
Hope this helps you on the way, once question is clarified.
RegardZ.
Kari
#3 PostAuthor: Kari » Mon Mar 02, 2009 3:11 pm
I have bought a new piston set to my bike. It's 70mm pistons (1000cc)
I wonder how to put rings to a set of barrels without a ring compressor?
Or if any know where I can buy or loan a ring compressor for this 1000cc engine.
Sorry for my bad language!
/Kari
#4 PostAuthor: Ginger Bear » Mon Mar 02, 2009 3:14 pm
Kari, have a look at this old thread of Piggy's, scroll to the bottom of the page for your answer.
http://z1ownersclub.co.uk/forum/viewtop ... &start=135
Kari
#5 PostAuthor: Kari » Mon Mar 02, 2009 8:11 pm
Ginger Bear wrote:Kari, have a look at this old thread of Piggy's, scroll to the bottom of the page for your answer.
I have read this now. But is this really a safe way to use?
Garn 1
#6 PostAuthor: Garn 1 » Mon Mar 02, 2009 8:15 pm
Kari, if you are putting 1000 (70mm) pistons in a set of 1015 barrels, it is easy, as there is sufficient chamfer to allow the rings to enter the cylinders with ease.
If you are fitting 1000 pistons to a set of 903 barrels that have been bore out, it is difficult, as there is usually no room for a chamfer to allow the rings to enter the cylinder. In this case you need 4 hands (a mate to help!).
I put the centre two pistons in the barrels first and the outer ones after. Don't forget the bottom gasket, the o-rings and the dowels Also required is a clever set of hands and fingernails.
RegardZ.
Kari
#7 PostAuthor: Kari » Mon Mar 02, 2009 9:00 pm
:( Yes! I have a 903cc barrels bore to 1015cc . I will try in the end of this week with helps of 2 extra hands!
Thanks for all tip!
#8 PostAuthor: Pigford » Mon Mar 02, 2009 9:07 pm
Kari, my RedZed was 903cc barrels with 1045cc Wiseco.....
Plastic bottle worked a treat...... :wink:
but if you're unsure, get some help.... Go slow, take your time & good luck :P
Garn 1
#9 PostAuthor: Garn 1 » Mon Mar 02, 2009 9:54 pm
Pigford, sorry I didn't read far enough into your thread that Ginger Bear suggested.
I agree, the plastic bottle method is probably the way to go when you have un-chamfered barrels. Although, those extra hands sure help in keeping the pistons aligned and stop them locking to one side.
I must admit, talking of ring compressors. I thought Kawasaki only made the one type for approx the 66 mm pistons. Perhaps, I'm wrong and they do make another for 70-72 mm pistons.
RegardZ.
Z1_Kerry
#10 PostAuthor: Z1_Kerry » Mon Mar 02, 2009 10:18 pm
Pigford wrote:Plastic bottle worked a treat...... :wink:
Mr Pigford that's a bloody brilliant idea :idea: KP
KP
Kari
#11 PostAuthor: Kari » Thu Apr 02, 2009 5:13 pm
I have fix it by my self with only my own fingers. :twisted:
Thanks to all help!
Users browsing this forum: No registered users and 108 guests
