HID Headlight...... Anyone tried this?
#1 PostAuthor: Ginger Bear » Wed Mar 04, 2009 7:59 am
I've toyed with the idea of fitting one of these
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120360190188&ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2F%3F_from%3DR40%26_trksid%3Dm38%26_nkw%3D120360190188%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
After discovering (thanks Taffus) the standard alternator will be working very hard to power a 55/60w (non standard) headlight bulb, I thought one of these would be good, as they are allegedly much brighter, but more importantly use less power........ Funky 'white' colour as well!
Any thoughts?
Taffus
#2 PostAuthor: Taffus » Wed Mar 04, 2009 8:15 am
I have been thinking of doing this conversion. Last time I checked it consumed 32W, I would need 2 for mine. Have you found a cheap source?
#3 PostAuthor: Ginger Bear » Wed Mar 04, 2009 9:12 am
The one I am looking at on ebay is £75.00 all in...... looks reasonable quality & the seller has lots of good feedback.
There seems to be a 'wealth' of em on ebay, some of 'em absolute cack, I'm sure.
I will try later today to look at some of the more reputeable suppliers, such as vehicle wiring products etc to get a quality/price comparison.
lta01
#4 PostAuthor: lta01 » Wed Mar 04, 2009 12:48 pm
I've been thinking about trying one of these as well, just not got round to it. I'm with you, brighter light, less power consumption and they say longer bulb life.
Only a couple fo things to check...is bulb protected against vibrations form bikes, and what are the dimensions exactly of the bulbs.
You might find the beam pattern is a bit off as the HID bulbs might have the filament ina differnet back/front position to the old bulbs we are used to using. Also chek the length of the bulb behind the lense casing... some are longer I think and will not fit inside the very crowded headlight bowl.
I'll be buying one in a month or so at latest just to give it a try on various bikes.
Taffus, why would you need 2....have you got dual headlights ? often those have differnet bulbs, sometimes 1 dipped/beam and one just beam ?
He who dies with the most toys wins .
