Hi, I am replacing all the seals on the Transmisson cover, I have ordered all new ones but have found a problem with the part numbers on the Kwak website. The part number for the clutch push rod seal (92049-1033-oil seal SC32487) is the same number as the seal on the rh side of the engine which goes in the timing cover, which is way to big. Has any got the right number for it.
Cheers Rob
Clutch pushrod oil seal incorrect part number
