Need for my Z1 key #754.
Thanks Mick
Key # 754
Key # 754
'78 Z1R, '80 Z1RII, '76 Z2 Z750 A4, '75 Z1 AME chopper, '80 Rickman CR1000, `72 Z1, 2001 ZRX1200R
wilsonsjw11
LTD Project
How can you tell what key number you have, ther is nothing on my key and nothing on the ignition switch that I can see?
Am I missing something where it is shown?
Otherwise I will need some blanks to cut off my only key.....
wilsonsjw11
wilsonsjw11 wrote:LTD
The number should also be on the seat lock and steering lock.
Regards
Steve
You're right about the numbers being on the seat lock and steering lock. However I would check the ignition switch in case anyone has changed one or the other at some point. You should find the number stamped along the side of the barrel, they're not terribly hard to remove.
