electrics
john b
electrics
#1 PostAuthor: john b » Sat Mar 14, 2009 11:43 am
can any one shed any light have rebuilt my z1b put new harness and all new switches every thing new but rectifier regulator starter solenoid when ignition turned on fuse just blows any one got any ideas doing my head at the moment
Mick Hayward
Electrics
#2 PostAuthor: Mick Hayward » Sat Mar 14, 2009 11:59 am
Hi John
Disconnect each part at a time to establish which bits and connections are cousing the problem. Something is going down to earth when you switch the ignition on.
Mick
Steve S
#3 PostAuthor: Steve S » Sun Mar 15, 2009 12:18 pm
I agree,if you have had it all to bits you will just have to do disconnects and try again,something is obviously shorting out...........unfortunately you will probably go through a lot of fuses.Start with the easy bits like lights,indicators,horn etc and work your way through,check your switchgear isn,t shorting on the bars all your earths etc. good luck. :D
john b
SORTED
#4 PostAuthor: john b » Thu Mar 19, 2009 9:26 pm
CHEERS STEVE AND MICK. WAS A LITTLE NICK IN WIRE IN IGNITION
Mick Hayward
electrics
#5 PostAuthor: Mick Hayward » Thu Mar 19, 2009 10:37 pm
Well done John glad you manages to sort it out.
Mick
