Keyster Carb Kits
bollypne
Keyster Carb Kits
#1 PostAuthor: bollypne » Wed Mar 18, 2009 11:26 am
Hi All. Just fitted carb kits to my A4. Question. There was 2 o-rings in the kit. 1 obviously for the Air Screw. Now the other ring is approx 50% bigger than the 1st, but where the hell is it from. I've found no other o-rings, not even on the airscrew i replaced!
All help greatly received.
Big Bol
Z900, ZRX1200r & a Z900rs Cafe
bollypne
#2 PostAuthor: bollypne » Wed Mar 18, 2009 12:04 pm
Just realised that i did not mean the Air Screw, though this does have an 0-ring, the smaller of the 2 provided is for the Drain Plug, the other which is 50% bigger is the one i'm asking about?
Colm
Big Bol
Steve S
#3 PostAuthor: Steve S » Wed Mar 18, 2009 1:45 pm
Is it part of the needle valve assembly?though i thought there was a round fibre typewasher for that, also i know there were extra gaskets in my kit for the Z1A....maybe they are extras? :D
bollypne
#4 PostAuthor: bollypne » Wed Mar 18, 2009 1:54 pm
Steve S wrote:Is it part of the needle valve assembly?though i thought there was a round fibre typewasher for that, also i know there were extra gaskets in my kit for the Z1A....maybe they are extras? :D
He Steve, did not seem to fit there. Main jet had a thin alloy washer, previous had a thin fibre washer.
Colm
Big Bol
Steve Cooke
#5 PostAuthor: Steve Cooke » Wed Mar 18, 2009 4:52 pm
It'll be the one for the choke.
bollypne
#6 PostAuthor: bollypne » Wed Mar 18, 2009 4:59 pm
Steven Cooke wrote:It'll be the one for the choke.
Cheers Steve, sorry but i'm non the wiser as to where it goes?
Big Bol
Steve Cooke
#7 PostAuthor: Steve Cooke » Wed Mar 18, 2009 5:22 pm
The choke/starter plunger is at the front of the carb with a black plastic boot on it and underneath that boot is the nut which is a 14mm spanner, undo that and the whole plunger can be withdrawn then you'll see the o ring.
Steve
bollypne
#8 PostAuthor: bollypne » Wed Mar 18, 2009 5:24 pm
mucho gracias or cheers
Big Bol
bakey
#9 PostAuthor: bakey » Thu Mar 19, 2009 12:24 pm
how much for the keyster kit mate?
mine needs a new float valve so im replacing the 4. Seen an OEM kit from wemoto for a tenner. They reckon it includes the valve, seat, o-rings and gaskets. 'A complete kit' for each unit.
Am i right in thinking that the seat should have a fibre washer though? has this been replaced in the kit by an o-ring?
anyone ever bought on of these? whats the quality like etc? Z-power do one for £15 i think, might just go for theirs.
''Who's motorcycle is this?''
tlc
#10 PostAuthor: tlc » Thu Mar 19, 2009 6:56 pm
I bought Keyster from a guy in Canada. Quality was good :D
Try Z Power by all means...............they don`t sell shite :D
bakey
#11 PostAuthor: bakey » Thu Mar 19, 2009 7:37 pm
float valve from z-power...£27. kerching!
kit including float valve and eveything else £15 :shock:
take it the dear one is genuine part and £15 kit is pattern? they told me it was the same on the phone like
phil churchett
#12 PostAuthor: phil churchett » Thu Mar 19, 2009 7:43 pm
Andy do a search on the "search forum".
I'm certain there has been some posts on the quality of some of these kits.
In fact i think Mike [Dogsbollox] has posted about them.
