Z1000 mk2
FLC
Z1000 mk2
#1 PostAuthor: FLC » Fri Feb 02, 2007 9:12 am
hi all a few questions on mk 2's,
i have a set of early cases i.e rocker cover, generator cover points and want to fit them on the later motor is this a straight swap?
Also is it possible to set up to run without battery?
many thanks in advance Mick.
#2 PostAuthor: Rich » Fri Feb 02, 2007 9:57 am
If by early cases you mean Z1000A2 and before -
The points cover will fit.
The alternator is different and the earlier cover won't fit.
The cam cover will fit but may have slight differences unless it is a US import with the emission crap on top and then it will leave the holes to the ex valves uncovered.
You are probably best to leave the battery on as your ignition will have a more stable supply.
FLC
#3 PostAuthor: FLC » Sun Feb 04, 2007 9:35 pm
thanks for the info, dont know what year they are off, am mostly wanting to change the rocker cover (which is i think a quite late one as it has a cast radius line above were the seal goes) anyway thanks again. Mick.
