Know anyone that can create one off parts?
martinz1000r
#1 PostAuthor: martinz1000r » Thu Apr 02, 2009 3:51 pm
I need a few spacers made up to mount things like rearsets and oil cooler bracket to my Lawson project. Has anyone got a lathe that can do these for me if I supply spec and drawings?
Obviously happy to part with beer vouchers........
KZCol
#2 PostAuthor: KZCol » Fri Apr 03, 2009 7:20 am
What do you require?
I have a machine shop and I can get away with doing small bits and bobs.
Col.
martinz1000r
#3 PostAuthor: martinz1000r » Fri Apr 03, 2009 9:14 am
Hi Col, thanks for the reply.
I need 2 spacers to hold a rearset away from the frame. I also need some spacers to hold an oil cooler at the right angle to the frame. This should be a case of 2 spacers on an angle for the top fitting and then 2 longer sleeves for the bottom fixings. If you can give me an email address I will send you exact drawings with angles and dimensions.
Cheers!
Martin
KZCol
#4 PostAuthor: KZCol » Fri Apr 03, 2009 12:18 pm
Martin,
PM sent with details.
Col.
martinz1000r
#5 PostAuthor: martinz1000r » Tue Apr 14, 2009 7:32 am
Many thanks to KZCol. Rapid turnaround, excellent work and highly recommended! :D
KZCol
#6 PostAuthor: KZCol » Sat Apr 18, 2009 2:16 pm
Thanks for the praise Martin.
If anybody else requires parts machined let me know and I'll see if I can help you out.
Col.
