GPz Gloss Black Cases.... How to Re-finish?
#1 PostAuthor: Ginger Bear » Fri Apr 03, 2009 10:06 pm
I want to get a set of GPz cases (clutch cover, rotor cover etc) finished, in a black hi gloss finish as close to the original as possible.
Only method I can think of is powder coating. Anyone tried anything different, or have any suggestions?
big green bus
#2 PostAuthor: big green bus » Fri Apr 03, 2009 10:31 pm
i had mine powder coated gloss black looks spot on it has been on for a few years now
MaineKZ
#3 PostAuthor: MaineKZ » Sat Apr 04, 2009 7:55 am
Hi GB
If you want durability and near OEM finish, get em blasted and 2 pack sprayed by Doug Cox. See my '73 resto' thread for pics of his work. Mine are done satin, but he's happy to do full gloss too.
Kawasaki didn't use powder coat on their motorcycle range - that was only used on their range of commemorative kitchen drying racks :wink:
contact Doug Cox at RD Cox and Son, Reading, Berks.
Redbeard
#4 PostAuthor: Redbeard » Fri May 08, 2009 7:19 pm
GB, I've read a bit about PJ1 paint on a gpz forum. Thorough prep is vital, gloss is harder to obtain, but it gets good feedback.
http://www.pj1.com/
Satin finish:- crankcases, barrels, head, rocker cover & gearbox cover
Gloss finish:- clutch cover, pulser cover & front sprocket cover
Might be worth a look.
1979 Z1000ST
Steve Cooke
#5 PostAuthor: Steve Cooke » Sat May 09, 2009 6:52 am
If you want durability then Powder coat or stove enamel is best, if original is your aim two pack them.
