carbs
hillbilly
carbs
#1 PostAuthor: hillbilly » Tue Apr 07, 2009 7:44 pm
can someone tell me what the difference between z carbs and cv carbsis,and do they work on all bikes. :?:
#2 PostAuthor: Pigford » Tue Apr 07, 2009 7:53 pm
Zed carbs are old & basic... but work OK... They are basic SLIDE carbs with a direct like from SLIDE to THROTTLE CABLE :wink:
CV carbs are more complicated & often make engine run 'smoother ' but are a pig to tune. The CV (Constant Velocity) bit is ofter destinguished by the top of the carb. This contains a diagphram which controls the movement of the SLIDE... The throttle cable only opens a butteryfly valve, which effects the venturi pressure - which in turn effects the pressure in the diagphram - which in turn lifts the slide :|
CV carbs are best avoided coz the diagphrams can split/perish with age & cost £££ to replace them :evil:
Swapping carbs form bike to bike can work... but more often than not.... :?? :| :evil: :cry:
hillbilly
#3 PostAuthor: hillbilly » Tue Apr 07, 2009 8:01 pm
cheers mr pigford.now ive got noledge to avoid them. :lol:
JohnC
#4 PostAuthor: JohnC » Wed Apr 08, 2009 2:09 pm
GSXR1100 CV / flat slide carbs will certainly work OK (in fact pretty well) with a Zed with larger inlet rubbers (Z1000A1 1015 Wiseco in this case), oh and some slight float height changes (The Gixer engine sits at a forwards slanting angle compared to the Zed). This is what I have atm but I'm still looking for 33 -34 mil smoothbores for both looks and (hopefully) more power and adjustability (££££££) :) :shock:
All I needed was a main jet change with the Gixer carbs and I've been OK with them for 8 years with no probs at all. Way back I seen them used with a nice Zed in Streetfighters mag and managed to pick a set up for £50.
Pigford is correct with his info about the diaphragms but I've been OK. Tuning them was a no brainer, even balancing them was easy, perhaps luck on my part, who knows???
If you need any more details just let me know. (in fact don't bother as I've just realised you are an ignorant tw@t) :roll:
similar or same as these if I remember correctly, £9.50 current bid.....
http://cgi.ebay.co.uk/Suzuki-GSXR-750-1 ... 240%3A1318
greenlaningxt
33 Smooth Bores
#5 PostAuthor: greenlaningxt » Wed Apr 08, 2009 9:43 pm
I have a set of VM33mm smooth bores that are for sale at the right price!
Make me an offer if they are what you want
Harris Z1000, Several other Road, Off Road and Trials Bikes, Delica Exceed
http://www.greenlaning.co.nr
JohnC
#6 PostAuthor: JohnC » Wed Apr 08, 2009 10:11 pm
pm sent.
JohnC
#7 PostAuthor: JohnC » Fri Apr 10, 2009 7:08 am
Hi I've sent a pm but I think your inbox may be full.
I'm going away this weekend but will be back on Monday sometime.
John
hillbilly
#8 PostAuthor: hillbilly » Fri Apr 10, 2009 7:23 pm
sorry but have you got any for me,seeing as it was my thread.if you want sumat go in the wanted forum. :evil:
#9 PostAuthor: Rich » Fri Apr 10, 2009 7:33 pm
Don't get all upset Hillbilly. Unless you're running over 1100cc 33s will be too big for your engine. I do hear 34CVs are a good replacement for 29 SBs have a look on Wired Georges site for details
http://www.wgcarbs.com/index.php?option ... &Itemid=30
hillbilly
#10 PostAuthor: hillbilly » Fri Apr 10, 2009 7:39 pm
im running an 1198cc bigbore kit.and am after some carbs that would help to run properly.i dont think 28mm standard carbs would suffice.
JohnC
#11 PostAuthor: JohnC » Sat Apr 11, 2009 4:14 pm
hillbilly wrote:sorry but have you got any for me,seeing as it was my thread.if you want sumat go in the wanted forum. :evil:
Emm if this was directed at me, then you need to wind your neck in ffs. I never asked in here for carbs, I was offered them after making a comment. Thats the last advice I'll be giving you matey. Forum jobsworths like you need to get a life.
:down
hillbilly
#12 PostAuthor: hillbilly » Sat Apr 11, 2009 4:17 pm
go suck an egg.
JohnC
#13 PostAuthor: JohnC » Sat Apr 11, 2009 4:20 pm
Yeah, you'll go far with an attitude like that.
#14 PostAuthor: Rich » Sat Apr 11, 2009 5:01 pm
No 28s will be a bit small. Who was talking about the 38 flatslides?
zeroed
#15 PostAuthor: zeroed » Sat Apr 11, 2009 5:16 pm
..Tea anyone? :)
