New Hagon shocks
Z.O.A
New Hagon shocks
#1 PostAuthor: Z.O.A » Thu Apr 09, 2009 11:12 am
I finished doing the forks and fitted everything back on the bike yesterday, so she's back on two wheels again.
I hopped on just to give the suspension a quick check, this was my first time to actually even sit on the bike since starting work on it, anyway I have fitted new Hagon shocks and I noticed straight away that on the rebound at the top of the stroke there was clunk coming from the back which I could feel as well as hear.
Everything on the bike is tight and clear, swingarm pivot, bushes, etc all perfect.
I stuck back on the old shocks this morning just to see if it was still there but there was'nt a problem at all.
The bushings and rubber mounts on the new hagons are all spot on and they are the right ones for the bike (z900 a4).
I reckon maybe I just got a bad set and was unlucky, I just wanted to know if anyone on here has had any similar problems with them??.
The shocks are the standard type by the way, with only adjustable spring preload.
smeg918
#2 PostAuthor: smeg918 » Thu Apr 09, 2009 7:48 pm
Hi, if there was too much pre-load it might cause the clung, but the re-bound damping should stop that. if the pre-loads not set to high then I quess it might be a problem with the re-bound. Contact Hagon see what they say.
