Glasses
Glasses
Bit of help/ advice needed... I have started wearing glasses when riding my bike, which are great when its dry but I did a couple of hundred miles yesterday in the rain with a couple of stops, so was pretty damp by the time I got home. My pinlock visor worked great but my bloody glasses were steaming up towards the end... whats the answer? is there one.
If i leave the visor open a bit it gets rain in the inside... my hat is well ventilated at any thing over 30mph its just shite in traffic.
wodda you lot recon
Baza
wodda you lot recon
Baza
Baza
Baza,
Find a dive shop and get some anti mist solution or use saliva. Might sound yuk but it works.
This stuff is available from the net and will probably be the answer
http://www.c-clear.biz/
Else use some glycol and water
KP
post
Fairy Liquid,smear lightly on the inside of the visor.wipe it well off and I guarantee you wont mist up same on glasses.
Ted
must be Fairy though.Other branded names dont do it
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
KE250
KZ1200
Puch Maxi
and me ol Granada
I have tried all sorts of things recomended for inside of visors when i was racing. best thing i found was fairy liquid and thats what i use now, trackdays and on the road, should be ok with your glasses just takes a bit off practice to get the amount used correct. (only needs a very little bit). just wipe it off with a clean soft tissue.
HANDS THAT DO DISHES CAN FEEL AS SOFT AS YOUR FACE WITH MILD GREEN FAIRY LIQUID.
Hi
Mikey I thought the little anti fog spray were to make fog go away
could do with some here its a peasoup jobby.
Ted
Ted
KE250
KZ1200
Puch Maxi
and me ol Granada
KE250
KZ1200
Puch Maxi
and me ol Granada
Maralyn, I was playing, although my eyes are buggered, I also had a hole drilled in one of them a few years back (I forgot about that) then there is the getting old part of it .
Thanks lads will give the fog off, washing up liquid a go on the glasses, the visor isn't a problem as pinlock system is brilliant.
Mikey, I had that stuff for my griffin clubman what a waste of time , you saved yourself a good few shillings there.
Baza
Baza
Baza
