Which carbs ?
Monk
Which carbs ?
#1 PostAuthor: Monk » Sun Apr 12, 2009 5:03 pm
Hi all
I am looking to change the carbs on me z1000a2.
Any suggestions on a suitable replacment without going for the big money cr's and smoothbores.
The motor is standard and I am looking for a set of carbs that will bolt straight on (well, nearly) and run good with the standard 1015 motor.
gsxr / fzr / zx9.....?????
Padders
#2 PostAuthor: Padders » Sun Apr 12, 2009 5:18 pm
Hi are you looking to change for more power or because yours are faulty. Only asking as I have a set of GS carbs that came fitted to a Z900 that work fine.
Monk
#3 PostAuthor: Monk » Sun Apr 12, 2009 5:21 pm
Hi Padders
The only reason I am thinking of changing is mine are getting a bit old and leaky, also take a lot of setting up due to age.
These gs carbs.....slides ?
What size ?
Bolt straight on ?
z2.john
#4 PostAuthor: z2.john » Sun Apr 12, 2009 5:24 pm
I think the A2 carbs were 26mm. An easy upgrade would be the 28mm carbs fitted to the Z1R and some other later big Zeds
John
Monk
#5 PostAuthor: Monk » Sun Apr 12, 2009 5:27 pm
Cheers John
Me thinks Padders gs1000 carbs probably 28's as well, trouble is all those type of carbs are still 30 year old and I might jump out of the frying pan straight into the chuffing fire !
Padders
#6 PostAuthor: Padders » Sun Apr 12, 2009 9:02 pm
The carbs are on the Z900 at the moment will be pulling them off this week and fitting some Z900 ones. I will measure them when they are off the bike. Work fine though.
