carbs
zedrider
carbs
#1 PostAuthor: zedrider » Tue Apr 14, 2009 10:57 pm
hi brothers and sisters . i have a z1000 ltd she was a american spec fuel injected model . all that was removed before i got her . now what i have on there is a set of mecunis . she has 2 T peice fuel intakes manual choke on the side the tickover ajuster in on the top . throtal is via two cabels one pull one return . now my question is this the T peice goes between the outer and inner carbs on the left and right . it has a moulded ridge on the outer edge and one set in a liltel further in before the t joint when i pulled the carbs a part some small bits of o ring fell out they were perished and i`m unable to tell what size they were . i have phoned zpower today who tell me that there should not be any o rings fitted . anyone know the answer to this ? many thanks
zed
Steve Cooke
#2 PostAuthor: Steve Cooke » Tue Apr 14, 2009 11:08 pm
They shouldn't be on there, I've come across that myself, they where probably leaking and someone has put o-rings on to try and seal them, you really need new ones which I think are just over twenty quid from ZPower
#3 PostAuthor: chrisu » Wed Apr 15, 2009 7:17 am
agreed - definitely no O rings. A previous bodge methinks......
I had the same problem and had to get new ones from Z power.
Taffus
#4 PostAuthor: Taffus » Wed Apr 15, 2009 7:20 am
Are they CV carbs?
zedrider
#5 PostAuthor: zedrider » Wed Apr 15, 2009 11:24 am
no there not cv carbs there slide but i`m thinking about geting some cv 34 carbs from a gixster
zed
Garn 1
#6 PostAuthor: Garn 1 » Sat Apr 18, 2009 5:47 am
Agree with all about .. "no o-ring on the Mikuni carb Tee pieces", with the exception of smooth-bores.
I have actually tried to repair these tee-pieces by inserting an o-ring, however, it's hard to get an o-ring thin enough. I was thinking a smart machinest coulds probably turn a nice groove on these and fit a standard O-ring, for a good fix!
RegardZ.
JohnC
#7 PostAuthor: JohnC » Sat Apr 18, 2009 11:48 am
PTFE tape?
Users browsing this forum: Bing [Bot] and 54 guests
