Lubed Up or Dry ?
Lubed Up or Dry ?
#1 PostAuthor: Ginger Bear » Thu Apr 16, 2009 4:47 pm
I have just spent ages cleaning of the old gasket from my GPz cam cover. To aid removal in the future should I smear a little grease on the new gasket or not :?
Your thoughts please gents.
maralyn
#2 PostAuthor: maralyn » Thu Apr 16, 2009 4:51 pm
I always use vaseline on all but head gaskets, it does it for me. :)
Some days I wake up Grumpy.
..................Some days, I just let her sleep.
#3 PostAuthor: chrisu » Thu Apr 16, 2009 4:57 pm
definitely wet.........
Steve S
#4 PostAuthor: Steve S » Thu Apr 16, 2009 5:07 pm
I lube them up a little too.......... :D
GEZ635
#5 PostAuthor: GEZ635 » Thu Apr 16, 2009 5:21 pm
Ive never used anything but the gasket. I know people use grease, vaseline etc but there is no need in real terms, but I guess it cant do too much harm if other people do.Some gaskets have an adhesive in them that works as the engine gets hot to make a proper seal as we all experience when trying to get base gaskets of the crankcase face and bottom of the barrels!
Gez
#6 PostAuthor: Ginger Bear » Fri Apr 17, 2009 7:17 am
Thanks Guys
Lubed it is then!
