reg/rec???
mick znone
reg/rec???
#1 PostAuthor: mick znone » Sun Apr 19, 2009 7:38 pm
Guys, is it the same combined reg/rec for the z1,z1a,z1b? one green block, one earth cable, one single white wire with double connector? Apparently you connect two wires from the rectifier to the double conector, but i have loads of wires coming out of the rectifier, confused :??
floydsz1
#2 PostAuthor: floydsz1 » Sun Apr 19, 2009 8:00 pm
Hi Mick,
Just been into me workshop and had a look at mine (Z1A) to make sure.
green block plugs in as normal,
black wire goes to earth on the engine, (small bolt behind kickstart under rear engine mount),
the white double female has one white wire from the fuse and the other white wire is from the generator (male bullit connector)
mick znone
#3 PostAuthor: mick znone » Sun Apr 19, 2009 8:06 pm
thanks for doing that Floydsz1, will try again in the morning, so the plastic block connector from the rectifier becomes obsolete i guess?
floydsz1
#4 PostAuthor: floydsz1 » Sun Apr 19, 2009 8:25 pm
Thats correct Mick,
The white block connector is not used. Some people cut the wires off the rectifier and plug the connector in so if anyone looks it looks original,
mick znone
#5 PostAuthor: mick znone » Sun Apr 19, 2009 9:16 pm
good man Floydsz1, i hate electrics as a builder and i hate them on my bike, thanks again :D
Davy Doherty
#6 PostAuthor: Davy Doherty » Sun Apr 19, 2009 10:56 pm
Can the rectifier be left plugged in?? will it do any harm..
Retro900
#7 PostAuthor: Retro900 » Sun Apr 19, 2009 11:51 pm
I'm assuming at least one of you may be using the electrex replacement,
i got to get one in the next couple of weeks, are they any good or should i try for an oem part?
Garn 1
#8 PostAuthor: Garn 1 » Mon Apr 20, 2009 8:15 am
Interesting question Dave D.
Can the rectifier be left plugged in? Will it do any harm? ..
The Combined reg/rectifier (z1 series) can be plugged in either the white or the green connector. Most plug it in the green.
Now. if the rectifier was left in, and connected, it would be receiving the 20 volts odd Ac from the alternator, via the blue plug and would be rectifying it to DC. This would then go the combined unit, which is already receiving the same 20 volts AC ...... this voltage would be also rectify and both sources would be regulated.... so, I would say, no damage!...Too complicated for me!
I would just leave the rectifier disconnected!
Perhaps some electrical wiz coulds handle this.?
RegardZ
mick znone
#9 PostAuthor: mick znone » Mon Apr 20, 2009 8:44 am
Garn 1 wrote:Interesting question Dave D.
RegardZ
:shock:
mick znone
#10 PostAuthor: mick znone » Mon Apr 20, 2009 8:49 am
Retro900 wrote:I'm assuming at least one of you may be using the electrex replacement,
at least one of you :ooer personally im using the pmc part from zpower, straight connection :roll: unless you are scared of electrics like me :tick
DogsbolloxofZ1B
#11 PostAuthor: DogsbolloxofZ1B » Mon Apr 20, 2009 3:59 pm
Same synchronised source voltage so should be fine.
tlc
#12 PostAuthor: tlc » Mon Apr 20, 2009 4:47 pm
Just connect the spare 20volt AC to your Purdybrush :lol:
mick znone
#13 PostAuthor: mick znone » Mon Apr 20, 2009 5:04 pm
tailiftchris wrote:Just connect the spare 20volt AC to your Purdybrush :lol:
purdy brushes, best in town TLC, wouldnt use anything else :D
PAULJAC47
#14 PostAuthor: PAULJAC47 » Mon Apr 20, 2009 7:47 pm
Just looking at the Tour Max reg/rectifier 716835----RGU-405 I have purchased for my project Z1B
This has no instructions with it so can anyone help??? it has a white plug with two yellow wires and one black it also has a brown wire with a male bullet and a red and white with a male bullet......Thanks Pauljac...
floydsz1
#15 PostAuthor: floydsz1 » Fri Apr 24, 2009 3:04 pm
RegardZ
I just took both the old rectifier and the regulator off and put the new pmc combined unit under the battery box and pluged it in, simple.
