Which Brake pads?
Steve R
Which Brake pads?
#1 PostAuthor: Steve R » Tue Apr 28, 2009 6:49 pm
On the way to the MOT today was not to impressed with the front brakes, realised I have never put new pads in so they are probably 15 years old, still not worn but... ?
So think it would be good idea to change them, its twin drilled discs, standard Z1000 calipers, what should I use?
outlaw
#2 PostAuthor: outlaw » Tue Apr 28, 2009 7:19 pm
If you do not want to buy new rough them up abit as they may be glazed, a guy who does mot,s told me that trick,
sp.milne
pads
#3 PostAuthor: sp.milne » Tue Apr 28, 2009 7:58 pm
http://shop.wemoto.com/pictures.dyn?u=1914614qqq5828053
Had the same trouble myself changed pads to these 10x better
tlc
#4 PostAuthor: tlc » Tue Apr 28, 2009 8:08 pm
Just put EBC in my rear caliper and was impressed.
mick znone
#5 PostAuthor: mick znone » Tue Apr 28, 2009 8:43 pm
how hot do peoples front discs get?mine i can hold with my fingers but i wouldnt put my dangley bits on there.
#6 PostAuthor: Pigford » Tue Apr 28, 2009 8:58 pm
Mine get really hot in the sun :|
Steve R
#7 PostAuthor: Steve R » Tue Apr 28, 2009 9:47 pm
What your dangly bits, best put lots of factor 30 on then get Kelly Brook to rub it in for you !
PAULJAC47
#8 PostAuthor: PAULJAC47 » Tue Apr 28, 2009 10:01 pm
I have found non sintered pads to be better less squealing as no metal bits in, probably wear a bit faster though!!!
