Z1 LH Switchgear
Nosher903
Z1 LH Switchgear
#1 PostAuthor: Nosher903 » Mon May 04, 2009 6:07 pm
I'm looking for a replacement set of LH swithgear after my HI/LO switch broke. I'm not after anything special, just something that works. Thanks!
GEZ635
hi
#2 PostAuthor: GEZ635 » Mon May 04, 2009 6:31 pm
The hi/low switches are normally available on ebay(usa) and are easy to change. I may have one so I will have a look for you.
Gez
GEZ635
hi
#3 PostAuthor: GEZ635 » Mon May 04, 2009 6:37 pm
pm me your number as I have a nos hi/lo switch part that should sort you out.
Gez
Nosher903
#4 PostAuthor: Nosher903 » Tue May 05, 2009 5:36 pm
Thanks for the reply Gez - I was out and about today and gave Z Power a call. They had them readily available for 30 quid so I took the plunge. Again, thanks for the reply.
