fitted new generator and regulator rectifier to my 77 zed expecting everything to be well but nothing done all the tests that it tells you to in the manual everything checks out but still no electric can anyone please help me thanks
mac
generating system
mac
mac got a multi meter
start at battery, all earths, coils, right the way through the system you'll find it.
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
problem solved
thanks for your help turns out went through ever test found nothing but with the starter clutch slipping as well kenny deduced that the bolt holding the magnet to the crank must be loose and wa la hail the great god kawasaki kenny harley an thanks for everybody elses comments again thanks
mac
mac
