Cam Cover
bigmac103
Cam Cover
#1 PostAuthor: bigmac103 » Sat May 16, 2009 9:26 pm
Hi All,
Is there a certain sequence in tightening the bolts on the cam cover and what is the Tq you use?
Any help always appreciated.
B
Lost in the desert somewhere
#2 PostAuthor: Ginger Bear » Sat May 16, 2009 9:41 pm
BigMac, no real sequence, but I would start from the centre & work outwards. Torque setting according to my Haynes manual is 0.8kg, but in reallity, that is just a gentle nip.
PaulMceleney
Chunks
#3 PostAuthor: PaulMceleney » Sat May 16, 2009 9:52 pm
its best to use a spanner to do this because they snap off to easy
bigmac103
#4 PostAuthor: bigmac103 » Sat May 16, 2009 9:54 pm
Good advice. Thanks guyz
BShaw
#5 PostAuthor: BShaw » Sun May 17, 2009 12:40 am
I was taught by my dad that proper spanners are the size they are so that you dont over tighten bolts when using just your fingers... if that makes sense.
Baza
#6 PostAuthor: Pigford » Sun May 17, 2009 7:53 am
True Baz........ Torque wrenchs are OK for bigger stuff... but a "real" mechanic can "feel" the force :wink:
Users browsing this forum: No registered users and 109 guests
