Could this be the problem?????
mikey
#1 PostAuthor: mikey » Sun May 17, 2009 4:08 pm
Regarding the problems ive been having lately with my A2 spluttering and misfiring, well riding to and from the southwest meet today hit some very heavy showers and the problem got worse and i was also getting a small electrical shock from the clutch and brake levers every time i used them could there be a problem somewhere in the handlebar switches that is causing the spluttering and misfire????
PAULJAC47
#2 PostAuthor: PAULJAC47 » Sun May 17, 2009 4:13 pm
Check the engine kill switch Mikey always a favourite for wet weather probs!!
Cheers Paul J..not one of the repro units from Z power by any chance? there was a bad batch recently.....
mikey
#3 PostAuthor: mikey » Sun May 17, 2009 4:25 pm
Cheers paul yes it is a zpower one but was fitted just before yorkshire rally last year, have a look tomorrow to cold and wet at the moment
Big John
#4 PostAuthor: Big John » Sun May 17, 2009 5:02 pm
Mikey, do you have the wiring running through the handlebars? Had starting problems on my B2 and traced it to the wiring chaffing on the handlebars it definitely sounds like the wiring to switchgear or switchgear.
mikey
#5 PostAuthor: mikey » Sun May 17, 2009 5:33 pm
No john mine run outside the bars but thanks for the input
tlc
#6 PostAuthor: tlc » Sun May 17, 2009 5:40 pm
Mikey. I think you should check the coils.
My old KH250 burned a carbon trace down the outside of the coil to earth which only became apparent in the wet. In the dry everything was fine. I was able to see a clear mark where it had gone.
Also 12v 10a won`t give you a shock, but 15,000 will !
mikey
#7 PostAuthor: mikey » Sun May 17, 2009 6:08 pm
Wasnt a shock like realy bad just like when you turn an engine over and you got the ht lead in your hand
tlc
#8 PostAuthor: tlc » Sun May 17, 2009 6:21 pm
Like I said Mikey :roll:
Try another coil perhaps ?
#9 PostAuthor: Ginger Bear » Sun May 17, 2009 6:40 pm
Mikey, you said earlier today that you had Dyna coils fitted. Check where the low tension (12v) connects, as this is very close to the mounting pillar & could short out. Look at mine & you will see I have cunningly slipped a bit of heatshrink over the pillar to avoid any shorts.Image
Sorry the pic is so big, but you should see what I mean.
#10 PostAuthor: Pigford » Sun May 17, 2009 6:41 pm
There you go Mikey... you're on the trail now matey..... :twisted:
Think we've all had a "whack" off the HT leads....... :??
mikey
#11 PostAuthor: mikey » Sun May 17, 2009 6:50 pm
Looks like could be on to something here guys have a look tomorrow
mikey
#12 PostAuthor: mikey » Mon May 18, 2009 6:26 pm
Right after spending all day working on the fekking thing this is what i found, couple ht leads looked a bit suss so replaced those and it improved things a tad, so next i put a harris back on it after all thats what it had on it before the shunt last year but no real change, so then had the carbs off stripped them a part but all the jets were clean, so thought id check float heights (dont have the tool for doing fuel level) and they were all over the place so done them put it back together and what a diffrence, took it for a spin and hey presto al is well again, dare say it could do with a carb balance after having them apart but yeah think its sorted fingers crossed, so seems like it was a mixture of a few problems?????
mick znone
#13 PostAuthor: mick znone » Mon May 18, 2009 6:39 pm
hey Mikey, glad you might
have sorted it mate, but could you
use the
enter button,
occasionally, i had to read some
of that in the
kitchen mate
:lol:
mikey
#14 PostAuthor: mikey » Mon May 18, 2009 6:49 pm
Wondered what i was doing in the
garden by the time
i finished typing it :lol: :lol: :lol:
#15 PostAuthor: Ginger Bear » Mon May 18, 2009 7:30 pm
Well Mikey, I ended up in me garage!!
Seriously though (if you can be on here), glad you have got it running well, but the float heights don't explain the electric shock treatment you were getting on the way home yesterday.
When I saw you in my mirrors I just thought you were a 'Smiley Mikey'........ Didn't know you were being electrocuted!!!!!!!
Users browsing this forum: Mally and 77 guests
