Can anyone remind me if the original steering damper fits straight onto the bottom yolk without a bracket, I can't remember seeing a bracket but have been told I need one.
Thanks for any advice
Mart
Z1B STEERING DAMPER
- steve bowdler
- mick znone
DurhamZ1B. I think you have resolved your problem, however, just in case you haven't. All the Z1, Z1A and Z1B's have the bottom yoke of the triple tree, with a boss that is drilled with a 8mm clearance hole, to take damper. Z900 & Z1000 do not have this hole, however, it may be drilled, in this bottom yoke to facilitate a damper.
Make sure you have the bracket on the RHS downtube of the Z1B frame, that takes the other end of the damper. Many are broken-off and filed smooth and painted.
As a foot-note: This down-tube bracket is often broken off, as a result of the steering damper seizing-up and causing the bracket to break and can cause damage to the head fins.
RegardZ.
RegardZ.
- mick znone
