lights on, engine off.
- mick znone
well there you go,
mot time, its raining, get bike out, starts on the button, switch lights on, engine dies. wont start again, leave it for five minutes, starts on the button, then, light switch kills it again, main fuse fine through the whole event. any tips please
- mick znone
Does sound like a wiring issue,check headlight and tail light bulbs are fitted correctly as well.Start with the easy things first, have you had it apart anywhere? switch could be earthing through the handlebars,do the lights work okay with engine off and will it turn over with the lights on?
good luck
good luck
- mick znone
- mick znone
i put a 60/55w bulb in a while back, it should be a 55/60w halogen, although i have used the lamp since, except, that was while riding, could it be that it wiorked then because the bike was charging at speed and it cant cope with the bulb at low revs??? im off to get the right bulb anyway. will try some insulation tape on the bars to stop any earthing.
ps it has started firing up on the button again.
cant see the bulb making any difference.Though did have a bulb that had blown and the fillerment was touching the inside casing off the bulb and earthing out.
with ignition on and engine not running can you switch the lights on ok.
unplug the switch from the rest off the harness under the tank and clean it.
plug it back in and remove the switch from the handlebars so its not earthing out and try starting the engine either button or kickstart.
switch lights back on, What happens ?
- mick znone
must have nicked it when i put new bars on months ago, but haven't used it in the damp.
- mick znone
