Help needed on this one.
This is strange, any working ok for many years the stop warning light in the tacho has stopped working. I have checked the bulb thats ok, but I have voltage at the bulb holder when the brakes are off but not enough for the bulb and when the brake is applied I get zero volts at the bulb holder, I would have thought it should be the other way around? I have tried another bulb and the existing bulb works, so any ideas you guy's as electrics arn't my favourite.
Bruce
Electrical Gremlins Z1A
