GPZ1100 B1 project now sold
SOLD, Bought this GPZ, 20 years ago, with an engine problem, broken ring on one cyl, the other 3 cylinders would clean with a hone, scored cylinder needs liner and piston, and basically a full set x4 of rings, wiring harness is in a bag, (was originally going to make a special), this came with carbs instead of injectors, it was a runner when bought though slightly smokey, 95% their, good project for someone, micron fork brace, ZRX1100, shocks, 27,000 miles, how much to ask what's your thoughts guys.
Always Learning.
Re: GPZ1100 B1 project
hi is this still for sale
Thats a unitrac ignition rotor.
I could be interested if its still for sale?
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there runs just needs paint.
1100 Zephyr Project.
1981 KZ1000 LTD
GPz 305 project
1981 KZ1000 LTD
Pistons don't look like Uni ones, if the carbs are 33s they're worth £250
GPZ1100 B1 motor ( injectors in the head )
Normal 26mm or 28mm VM carbs.
Price ???
Im not on this site much, tend to use Facebook, apologies GPZ is long sold, ill see if i can add to post or delete.
Always Learning.
You can just edit the first post and put Sold in the title.
