#1 PostAuthor: zed1015 » Sun Jun 12, 2011 11:35 pm
1428cc supercharged Light weight animal.
Daytime mot.
no lights (Except for a brake light) .
No frills (Except for a supercharger)
And no frame :D .(Well! not in the first pic anyway)
And everything (nearly) done in the shed with my large selection of hammers :shock:
Swingarm pivot mounted jig built to transfer engine mount points over to a soon to be very modified 750 Zephyr frame.
Zed motor,now a stressed member squeezed into 750 Zeph frame with the aid of a hacksaw and vaseline.
05 zx10r wheels forks and suzuki srad swinger and wooden mainstand
On its wheels.
Frame braced with rear suspension fitted, swinger changed to gixer 1000k4.
Subframe mounts welded on
Alloy subframe and (roadsign) seat fitted
Footrests fitted and fuel tank is a work in progress
wierac21
#2 PostAuthor: wierac21 » Mon Jun 13, 2011 12:05 am
Keep em coming :clap
sanderz
#3 PostAuthor: sanderz » Tue Jun 14, 2011 8:33 am
Another work of art in the making.
1428..... & supercharger :shock: holy moly!!
Wots up DOHC
#4 PostAuthor: zed1015 » Thu Jun 23, 2011 11:16 pm
PETROL TANK - PROGRESS SO FAR.
Started out life as a wayward road sign :wink: .
Upper shell welded inside
And out
TODAY.
Drilled a hole in the rear of the tank shell
And turned up this alloy bobbin (to take a rubber mounting strap)
Which was pressed in and welded on from the inside
For a neat appearance
Also spent hours with the wet and dry polishing out the weld seams.
Next job on the list is to weld in a base and make a front mount
(still plenty of opportunity for things to go horribly wrong so fingers crossed)
Andy M
#5 PostAuthor: Andy M » Fri Jun 24, 2011 3:17 pm
Good to see you've lost the wooden main stand in preference to a conventional side stand. Looking good... :up
#6 PostAuthor: paul doran » Fri Jun 24, 2011 4:55 pm
looking good Rob
will the Club Project be as good :lol: :lol: :lol:
k7
#7 PostAuthor: k7 » Sat Jun 25, 2011 9:44 pm
she's looking good Rob - another great bit of engineering and oh so much polishing and swearing lol ..........
Ride free and party hard
#8 PostAuthor: zed1015 » Sat Jun 25, 2011 10:53 pm
Woohoo :D .
Managed to weld in the base without it all melting in a heap.
Green outline is where i'll weld on a fuel baffle box which will hang between the subframe rails and provide a mount for the tap and a bit of extra capacity
#9 PostAuthor: zed1015 » Wed Jul 06, 2011 8:49 pm
REAR LIGHT MOUNT.
Little bit more progress this week.
Made up this alloy plate which will hold the rear light and form somewhere to hide the battery .
After welding it into the seat unit the welds were blended in so it looks like one piece.
And also forms the other half of the undertray
Light unit is ZX7R
Also had a swift session on the lathe and finished off the adjustable subframe struts.
As well as making up a threaded mounting stub
To take the fuel tanks front mount
Jappen
#10 PostAuthor: Jappen » Wed Jul 06, 2011 9:27 pm
Well done.... :resp
80-Z1000H
79-Z1000MK2
bart
#11 PostAuthor: bart » Thu Jul 07, 2011 8:29 am
some fantastic engineering going on,going to be stunning when it's finished. :more
Crofty
#12 PostAuthor: Crofty » Thu Jul 07, 2011 8:32 am
Really really inspiring stuff, keep it up. :D :D
sanderz
#13 PostAuthor: sanderz » Thu Jul 07, 2011 9:55 am
bart wrote:some fantastic engineering going on,going to be stunning when it's finished. :more
Second that :!:
Any clues to wot filler cap you'll be fitting?
Maybe put twin fillers on there - endurance style (just a tought)
Wots up DOHC
#14 PostAuthor: zed1015 » Thu Jul 07, 2011 10:08 am
Maybe put twin fillers on there - endurance style (just a thought)
Will be the race flush filler type maybe single maybe twin.
Depends on what i can lay my hands on.
Was thinking of making my own again but - been there/done that - so i've put a wanted ad on a few forums and am waiting to see if owt turns up.
#15 PostAuthor: Ginger Bear » Fri Jul 15, 2011 4:57 pm
Excellent stuff Rob. :resp
Users browsing this forum: No registered users and 163 guests
