Hello. I’m after part number 42032-070
It’s the top hat spacer.
Thanks.
Z1000 A1 rear wheel spacer
THEMACCLADS
- Regular Poster
Beer and Sex and ChipsNGravy - It's all a Macc Lad needs.
Re: Z1000 A1 rear wheel spacer
i might have one....
THEMACCLADS
- Regular Poster
No, but thank you. Appreciate your help with photo
It’s the spacer with one shoulder that sits on the sprocket side.
Ok Cheers...
THEMACCLADS
- Regular Poster
Sorry... disc side.
The diagram in the z-Power booklet is misleading.
Spacers 4 And 24 are pictured wrong way round.
Better picture on cmsnl.com website.
You may want to specify, wire wheels or alloys because I believe they are different sizes, I got the dimensions and had one made, it was easier. Good luck.
THEMACCLADS
- Regular Poster
Good tip that Cheers for “helping the aged”
Wire wheels.
Wire wheels.
- 8 Valve Mark
i have a couple of top hat spacers of vague kawasaki origins,off hand 30mm end to end n 17mm inner diameter (STD kawasaki spindle size).i also have one like yellow offered n could be machined down to fit,it's maybe wider end to end but only by 3 or 4 mm,not sure as I'm in cloudy Spain so can't be exact. pm your details n I'll post you a couple to f'about with.. probably about next wed/Thurs.
THEMACCLADS
- Regular Poster
Thanks for the offer Mark. Very helpful.
Managed to find and order a NOS one this morning whilst browsing over coffee.
Few nice little bits on full throttle projects.com
Thanks.
Thanks.
- 8 Valve Mark
good you sorted out mate. post up a pic n the dimensions incase my spare ones are of use to a fellow zhead...ride safe..
Users browsing this forum: No registered users and 140 guests
